SmartSDR CAT not connecting to the Flex 6500
The image above shows the current status of the Flex 6500. As you can see, FRStack, SmartSDR, SmartSDR DAX are all connected and the virtual com ports are in place. However, as you can see SmartSDR CAT is not. There is only one radio to choose from. I am running SmartSDR V 3.1.12. Today is the first time that SmartSDR CAT will not connect. No changes have been to the PC running Windows 10.
I would appreciate any suggestions.
73, Bob, KN4HH
When things get weird I close everything and restart from the beginning, lately I've jumped the gun a few times while radio is still booting up. Usually I turn on radio and go get coffee started and by then the software is cleared to go.
Thank you, Erika. I did as a precaution do a complete uninstall including drivers and a reinstall. Same results. Good idea on the coffee.
WhenI get word stuff I do a factory reset. Export the profiles, reset, then restore profiles.
Thanks, John. Yes, I did a factory reset and re-installed 3.1.12 including all drivers. Interestingly enough, all the virtual com ports do load.
Thanks again, Bob, KN4HH
Here is an updated image of the Flex 6500 with the SmartSDR CAT status box showing no connection. All three clients do connect to the radio and the virtual com ports are present. I have done a factory reset, completely uninstalled SmartSDR including drivers and reinstalled V3.1.2 All radio functions and all DAX functions are correct. I am unable to access the radio using other apps (WSJT, Fldigi, etc). Thank you all again for reading.
Bob, KN4HH
Sorry for all this bandwidth, folks . I did a Windows system restore and CAT now functions properly. Thanks for the comments.
73, Bob, KN4HH
So, windoze strikes again.
- 332 Community Topics
- 599 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 398 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 181 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 16 Aurora
- 912 Maestro
- 52 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 727 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
