Lost Control Window on main GUI Panel with TX P/CW Phone etc
The problem relates to one laptop other laptops are ok main GUI displays correctly.
I normally run with the Control Panel in separate windows, today one laptop during operation the Control Windows disappeared. (smartsdr v3.1.12)
I've search forum and manual I can't find how to restore the Control Panel window.
Everything seems to work ok, but I can't modify or view anything within the missing window.
Thinking corrupt software I uninstalled & installed again but windows still missing.
The task manager should TX Panel process is missing.
Ideas on how to recover the task / missing Panel
Thanks Neil g0ggg
  • Neil Rogers
    Neil Rogers Member ✭✭
    Further information, the issue is within the Windows User profile, not sure where.
    But if a new local user on the laptop is created the TX Panel returns.
    Therefore the issue is likely to be the user profile
    Neil g0ggg
  • N5DUP
    N5DUP Member ✭✭
    Is there a way within SmartSDR to get the control panels back?
    Len nailed the answer. There is no need to solve the problem with a sledgehammer. :).
    Just click the same button you clicked to hide it! :)
