5000A No Transmit audio and power output on SSB
AJP
AJP Member
edited November 2020 in FLEX Series (Legacy) Radios
Running PowerSDR 2.8 and have no output power or transmit audio on SSB via Firewire. In the computer sound recording parameters it shows Microphone and Line In "not plugged in". In the playback parameters it shows me using "Digital Audio (S/PDIF) as the default device. I've been messing with this problem for days. My question is 'can I wire a Creative Labs USB sound card adapter as my audio line in and out to have better audio control thru the line in/out jacks on the 5000? If so, what would be the setup?
  • AJP
    AJP Member
    Thanks Dudley... To clarify, I am using only the Flex supplied Mic. I have all of the recommended settings on the computer (WIN 7) and I am seeing my audio on the panadapter and all meters. When speaking into the Mic, and in monitor mode, TX audio is distorted and weak whether on SSB or AM. I am seeing full power carrier on AM without audio. Thanks again Dudley and is there anybody else with an idea.
  • WX7Y
    WX7Y Member ✭✭✭✭
    PowerSDR has a plethora of Audio settings that you can adjust, here how to CORRECTLY set the audio up so you may want to look for that here, https://helpdesk.flexradio.com/hc/en-us/articles/202118248-TX-Audio-Setup-Procedure-by-W1AEX-Rob .
    Over driving ANY section of all the adjustments will cause distortion, I would check the Leveler that always caused distortion on my voice, I also had to drop 1K on the TX Equalizer or I would sound nasally.
  • I'm having the same problem with my Flex 5000A. Low to no output with SSB, mic connected directly to the radio, tried two mic's. Speaking into the mic gives me just a few watts.
    Transmits CW and transmits a carrier and sidebands in AM and a carrier in FM.
    Did a factory defaults reset and did the self tests (Ctrl/Shift P). It failed the RX filter and TX filter tests initially, but then the TX filter fixed itself.
  • w7gz
    w7gz Member, Unconfirmed
    Marco, did you resolve this issue? I have the same problem in my new 5000a. I have full output in TUN, but no power out in SSB, although the mic waveform looks good on the spectrum display.
