Display of Flex-6500
Yes, it’s just a commercial, but it can be dimmed in the setup.
Other then display of personal info, it is only use is to display restart info. In the past before the major radio design for the 6400/6600 radios, the display could of been used for a minimal radio stand alone operation. This would have been had usefulness for no computer portable minimalist no IP network operation device operation. This would have been good for battery operation.
If the display can be controlled by SmartSDR, then in concept, the display could display other information. How about posing the question to Tim and then that could be a feature request for the type of data that can be displayed.
Mike,
This was brought up about 7 years ago. Many ideas for additional data were suggested and initially FRS agreed with adding some of them as well as suggesting some additional data elements. Obviously it never happened. Read about it below, I'd suggest adding your vote but I doubt it will ever happen now since the new models don't have the display.
https://community.flexradio.com/discussion/5637023/front-panel-display-an-idea#latest
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
6700 Win10 SSDR V2.4.10
Since this would be an improvement that would be only for 6300, 6500 and 6700 radios. It would be a piece of work that would not benefit the complete line of 6000 radios and use up valuable memory space that is needed for other needed improvements. Before the advent of the new line of radios, I would have really wanted to see useful and more robust features and uses for the display. At this point in time, it has now become rather irrelevant and I fear it will not even be considered by Flexradio.
Patrick, agree and actually the front panels are only on the 6500 & 6700. After 7 years and with many more beneficial ideas also not implemented, I would give it less than a 1 in 1,000 chance of happening.
Regards Al / NN4ZZ
The 6500 is discontinued as we know. There will be no more enhancements made. Only maintenance updates.
Bill, we understand that.
- 398 Community Topics
- 677 The Flea Market
- 190 SmartSDR+
- 195 SmartSDR for Maestro and M models
- 216 DAX
- 391 SmartSDR API
- 87 Aurora
- 331 FLEX-8000 Signature Series
- 987 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 317 Shack Infrastructure
- 222 Networking
- 840 Peripherals & Station Integration
