Questions About Buying and Using a Heil Pro Set 7 With a Flex 6600
Hi,
As I age, I am finding it easier to just sit back in my operating chare and use a headset with boom mic. I currently own a Flex 6600 (plain) and have more or less decided on a Heil Pro Set 7. Before ordering, I'd appreciate some feedback on:
- How do others like this headset?
- What cables/adaptors should I buy? I expect to plug in both the RX and TX audio into the rear panel of the radio AND control TX/RX with a switch which I understand is mounted right on the headset.
- Does the push to talk button come standard with this headset or do I need to buy a separate item with cable?
Any other feedback or suggestions would be welcome. Thanks and 73 de K8DXX
hi Bill
i use heil headset with my 6600m...like you just feels right
I have heil proset 5 and heil quietphone with #5 element
i prefer the quietphone headset cause i can turn on the noise canceling feature
and now i dont hear the dog barking or wife yelling at me ;-))
puts me in my own little world of radio....
the quite phone also comes with its own ptt swicth built in and no separate one needed
both heil headset are plug and ply with the 6600m with no adapters
but
with the connection in the back of the radio i use extension cables because i needed more cable to lean back in my chair
with the flex your can tune your transmit audio with the EQ
hope this info helps
Paul K3SF
Thanks. Yes it did. I wound up buying the Proset 6 with HC 6 microphone. Gigaparts had them for $134.90. Heil advised that these were a direct plug and play with my Flex 6600.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
