Tuning Flex 6600 with an external ATU.
I did build a 90 meter long longwire loop to serve as a 160m antenna. It does not tune with my Flex 6600 ATU but it does tune with MFJ-993B ATU connected to my ICOM-7300. I did disconnect the MFJ-993B from the 7300, put it on manual control, and connected it to the Flex 6600. Playing all tricks I did not manage to get the 6600 tune the antenna with the MFJ.
- How to you make the Flex 6600 tune an external ATU in general and MFJ-993B in particular.
- Which types of ATU are fit for use as an external ATU for Flex 6600.
Amos 4X4MF
Amos, I use an MFJ 929 which is pretty much the same tuner without the meter. It works very well. I set the tune power in the flex to 10 watts, and click the tune button. I don’t have an internal tuner. Is yours off?
John
Thank you for coming back.
- Which Flex are you using?
- Is it possible to turn the 6600 ATU off?
Amos 4X4MF
Hi Amos, Yes, you can turn the ATU off. Click the ATU button on the TX tab of the Radio Panel. The Tune button will still output a signal when clicked. If you use an external automatic tuner, be sure to turn off the internal tuner or they will chase each other looking for a match.
Len, KD0RC
John
Following your remarks and reading the manual again, I did finally manage to get my 6600 work on 160m with the new antenna.
Thanks again and see you on 160m FT8.
Amos 4X4MF
Good that you got it going. Stayed in Jerusalem last time, maybe Haifa next time.
- 391 Community Topics
- 665 The Flea Market
- 166 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
