SmartLink and Apple routers (Airport, Time Capsule, etc)
Member, Super Elmer Moderator
edited October 2020 in Remote Operation (SmartLink)
I just helped a gentleman running an Apple Time Capsule router (same as Airport Extreme with the built in backup drive).
We found out that the Airport routers do not support uPNP. We needed to use manual port forwarding. Here is a pdf which describes how to add port forwarding to the Apple router.
https://www.rainmachine.com/support/portforwarding/Port-Forwarding-Apple-AirPortExtreme-Router-for-HTTPS.pdf
You only need to add one port forwarding rule to the Apple Airport (or Time Capsule) router.
On page 4 of the PDF it shows how to add the port forwarding.. Here are the setting you need to enter.
Description: ​SmartLink
Public UDP Ports: ​ 22000
Public TCP Ports: ​ 21000
Private IP Address: ​ <enter the IP  address of the radio>
Private UDP Port(s): ​ 4993
Private TCP Port(s): ​ 4994
Click ​ Save​  button> The router will reboot.
Next go into SmartLink Setup and expand Network Settings. Click Manual and enter the following settings
Click Save then click the test button. You should get a green indicator and if you hover over it (SmartSDR) or click it (Maestro) the bottom section UDP and TCP should show pass.
Welcome!
  • Member ✭✭
    edited June 2020
    Dave
    Why the choice of ports 22000, and 21000 on the WAN side?
    On my Time Capsule,  I port forwarded WAN side TCP 4994 and WAN side UDP 4993, to the LAN side TCP 4994, and UDP 4993 ports. The SmartLink Test Came back with a green indicator after I rebooted the Time Capsule.
    Should I change my WAN side port assignments?
         SDRgadgets
    #FlexRadio IRC chat
       73, Jay - NO5J
  • Member, Super Elmer Moderator
    edited July 2017
    no, you can leave them as-is. Just what we used.
    Dave
  • Member ✭✭
    edited July 2017
    Dave
    Thanks for the quick reply! I had no particular reason to setup the 1 to 1 pairings I used, and thought I might have overlooked something important.
         SDRgadgets
    #FlexRadio IRC chat
       73, Jay - NO5J
  • Member ✭✭✭
    edited July 2017
    I think you also need to enable NAT-PMP also.....
    edited July 2017
    It was already enabled. Check the pdf article I lonked to in the above posting. Page 4 I believe. Dave
  • Member ✭✭
    edited July 2017
    You might want to do a DHCP reservation too.
  • Member ✭✭✭
    edited July 2017
    That I dd early on, setting static address for a number different devices.
  • Member ✭✭
    edited June 2020
    Dave - Thanks for posting this, it instantly enabled smartlink for me on my apple airport extreme. I was starting to think it was going to be very complicated but this worked perfectly and was super easy to follow. Thanks again!!!!!
    edited August 2017
    Glad it helped! Dave wo2x
  • Member
    edited June 2020
    I'm a new Flex6600 owner and have an Airport Express....this worked great.  Thanks Much - Tony W4TYB
    edited May 2018
    You are welcome. Glad it was useful. 73 Dave wo2x
  • Member
    Just tried this configuration tonight and it worked perfectly! Thank you
    You are welcome!
  • Member
    Dave. I have an Apple Airport Time Capsule router. It's so old it really should be replaced but that's another discussion. Thanks for posting this very helpful discussion.
    Got it working!!
    Dean
    Glad it helped Dean. I have upgraded to an Eero mesh system.
