SmartSDR is compatible to iOS 14
SmartSDR is compatible to iOS 14 (moving to the correct category)
However, due to a bug in iOS 14 it might happen that you can’t use SmartSDR to connect to your local Radio.
But there is a simple solutions. Just change the App to use a fixed IP Address of your Radio. For this, just go to Settings -> Show Extended Settings and select “Fixed” for “LAN mode”. Then, enter the IP Address of your Radio in the field below named “Network”. (No change on your Radio is required for this)
Now, you should be able to connect to your Radio again.
Once you do that, you may get asked by iOS for permission to access your local network by the App. Once you confirm this and gave the App permission, you can even turn back off the fixed IP LAN mode and change it back to “Discover” which is the recommended setting.
You will now also find a new Setting in the iOS Settings under Privacy -> Local Network.
Here, you should see an entry for SmartSDR which should be enabled. If you don’t see this entry, continue to use the fixed IP until you get the permission question from iOS.
On this screen, you can also re-enable Local Network access if you accidentally dismissed the permission question.
I expect this but to be fixed in the next iOS version but in the meantime, the aforementioned procedure will solve this problem.73,
Marcus
Yes, Mike that worked for the local connect. Thanks. However, it did not resolve it for using SmartLink.
well, hope that works, i guess in my post the other day i didnt note i was using IOS 14, hope this helps! will try when i get home. Thanks Mike!
yep, well i tried it on mine, local worked but like David smartlink didnt. Smartlink does show in the available radios but when you click it it goes back to connect screen, oh well half better than nothing! Thanks
Well there was a second software release for IOS.. So the newest and greatest is now 14.0.1 and as you can guess it didnt solve or help this problem...
When I try to connect I get an empty “Available Radios” window.....any idea what’s going on running iOS 14.0.1....
I'm still having the same issue off network... Still waiting for this "magic Apple update" that will fix this.
I found the errors of my ways.... Looks like SmartLink got an over haul recently, or since I have played remotely. Logging out and back in resolved my issue. Its great to have a radio again on my ipad and iphone.
- 384 Community Topics
- 643 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
