AG configuration with 3 antennas
I am posting it under Flex6600 as I do not see a category for Antenna genius.
I completed AG8x2 installation over the summer and here is the conflict I am trying to resolve.
Flex 6600 both Ant1 and Ant2 connected to AG Ant 1 and Ant2 inputs.
I have 3 antennas at the moment :
1st o - 6m monoband
3rd input - Steppir 40-10m
4th output - Vertical 80-160m
When I work 6m and Steppir - all good, Steppir on Ant 1 and 6m Monoband on Ant2 of AG.
When I try to work Vertical (80 or 160) and anything on Steppir both slices switch to Ant 2 and RX going to wide with attenuated signal.
I am using Stacks3 to assign antenna but my assignment should constantly change.
Any suggestions to avoid conflicts between antennas?
Sergey, KN7K
@Sergey KN7K This topic should be in the Station Integration category since it has to do with using the AG. I have moved the discussion to the Station Integration category so it has greater visibility with the Community members.
Sergey
Can you post a picture of your SmartSDR screen when this happens?
Also, can you test without the Stack 3? I am not familiar with the Stack 3 at all, so I don't know just how it plays.
Mike va3mw
Hi Mike,
Both slices basically show the Ant 1 for RX and TX and both in Wide RX, something like that
and does happening without Stacks3.
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
