MAC SDR configuration with WSJT-X
K6JV
K6JV Member ✭✭
Good Morning, can someone please provide me with the proper settings for the SDR for MAC program and WSJT-X. I am unable to get the CAT to work. Thanks. Doug, K6JV
  • George KF2T
    George KF2T Member ✭✭✭
    Screen Shot 2020-08-21 at 4.19.25 PM.png Screen Shot 2020-08-21 at 4.19.35 PM.png
    Ignore the reference to USB device in PTT - it's not selected. Use CAT.
  • K6JV
    K6JV Member ✭✭
    Thanks George, that got it. Now how do I get DAX to provide the audio without having the computer speakers active.
  • K6JV
    K6JV Member ✭✭
    Do I need a program like loopback?
  • Pete - W6OP
    Pete - W6OP Member ✭✭
    Yes, you will need Loopback or similar. Though you can just use the built in FT8 program unless you need Fox/Hound or want to run multiple instances.
  • K6JV
    K6JV Member ✭✭
    Hi Pete, thanks for the reply. Installed Loopback but can not get audio to WSJT-X. Would you mind sharing how you have yours configured?
    Thanks.
  • Pete - W6OP
    edited August 2020
    Lets see if a photo can explain it better than I can in words. My only problem is I can't transmit. It keys the rig and looks like its transmitting but I have no power out. As if the audio isn't getting to WSJT-X. Actually the TUNE button doesn't work either, just keys radio, no power out. This is the same configuration I have been using with dogparkSDR and Doug's xSDR6000.
  • K6JV
    K6JV Member ✭✭
    Thanks Pete, I actually got mine working with the addition of Loopback.
  • Pete - W6OP
    Are you able to transmit? If so, how does your's differ from mine?
  • K6JV
    K6JV Member ✭✭
    Hi Pete, my is configured as:
    Data bits- default
    Stop bits- defaule
    Handshake- hardware
    Mode- USB
    Could be the handshake
  • Pete - W6OP
    I restarted everything and it just started working. The mysteries of computers :)
  • George KF2T
    Pete, you may want to create two Loopback devices. One for TX, the other RX. See attached images.
    screen-shot-2020-08-21-at-4-00-54-pm.png screen-shot-2020-08-21-at-4-04-50-pm.png
  • K6JV
    K6JV Member ✭✭
    Glad you got it going Pete.
    Best 73
    Doug K6JV
  • Pete - W6OP
    Thanks George, 2 Loopbacks sound good. I was always wondering about only having one shared.
  • K4QXX
    K4QXX Member ✭✭
    I can't seem to get SSDR for Mac working with WSJT-X. Many of the options are greyed out on the setup screen.
    I have loopback setup for the audio but no long getting CAT to work.
    K4QXX
    Burch
  • K3DCW
    K3DCW Member ✭✭
    Burch,
    Did you setup CAT control in SmartSDR for Mac to use port 5002 in FlexControl mode?
    Do you have another logbook running (MacLoggerDX or RUMlogNG?) that can provide WSJT-X control? If so, do you have that enabled thereby creating a conflict on port 5002?
    There are lots of possibilities, but it is likely a configuration issue in one of the above areas.
  • K4QXX
    K4QXX Member ✭✭
    This is what I have setup in the Flex CAT control
    But I still get this in WSJT-X
  • K4QXX
    K4QXX Member ✭✭
    Well, I don't know what I did but all of a sudden it's working now. There was a long delay when I clicked on the "Test Cat" button but it finally turned green and I was able to make a FT8 contact.
