Crashes with new software
System
Member admin
This discussion was created from comments split from: Screen layout for SDR/Mac.
I have had several crashes since I have installed the software. The entire Mac computer crashes, not just the software. I can't run it for more than about 10 minutes and then the Mac gets a black screen and says something about a critical error has occurred and the Mac will reboot. Using on a less than one year old iMac with 128GB memory and i9 processor.-1
Some observations with my crashing problem. If I make the SDR window less than half the size on my screen, the software won't crash. If I resize the screen and it's more than 50% of the monitor, the software crashes after about 10 minutes.
Last night I opened 3 panadapters and sized them to about a quarter of the screen. I left it running all night an no issues. I opened a 4th panadapter to fill the last quarter of the screen and after 10-15 minutes, it crashed again. So it seems to be a combination of the SDR window size and the amount of screen that is used. This only happens on my 2019 iMac 27" 5K with an 8 core i9 processor and 128GB of ram.
If I run SmartSDR in "low Res Mode", I don't get the crashes and can run full screen. Of course, it doesn't look near as good and the graphics aren't very crisp.
When I run on my 2015 MacBook Pro 13" and my 2015 MacBook Pro 15", I have no issues. They both run fine.
So I don't know if the software doesn't like the 5K retna screen or if it doesn't like the Radeon Pro 580x graphics card.0 -
Can you capture the crash log and send it to me (michael@flexradio.com) . Do not send it to Apple.
I'll forward it to Marcus. If you have reported it to him, let me know so I won't duplicate effort.
Ok, I will try. When it crashes, it just doesn't crash the software. It crashes the entire computer. I guess it's like the Apple equivalent of the "blue screen of death" on a windows machine. After it crashes, the computer reboots.0
Interesting - I'll have to try running it full screen on my mac - same 27 inch display.
Update on my issue. I think the issue is/was with my computer and not the app. When I purchased the iMac, I bought it with 8GB of memory and then purchased 128GB and replaced it. I took the 128 out this morning and put the 8GB of original memory back in and ran the software for over 2 hours with no issues. I have now put half the memory back in (64GB) and have been running for over an hour with no issues. I will run this way for a few days and then add one of the two remaining memory cards back in. Either I have a bad memory card or maybe one of them wasn't seated correctly?0
are you using the spots feature? if so try turning it off.
Not using the spots feature. I believe my issue was a memory problem. Hasn't crashed now in 24 hours.0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
