Leaving the radio on for hours or days at a time
Does it hurt or burn the screen if I leave the radio on for days at a time ? Will the monitor go into a sleep mode if left on for remote work ? What is the proper way to leave the radio available for remote operation ? thanks John kb2huk
  • Tim - W4TME
    @kb2huk In this post, you asked a question where you wanted to get an answer, but the post was designated as a discussion topic. Please see the Message Board post Using New Q&A (Question & Answer) Feature for how to create a Question and Answer (Q&A) post. I went ahead and converted your post to a Q&A.
  • WX7Y
    WX7Y Member ✭✭✭✭
    edited August 2020
    You can also from SmartSDR close or Disconnect the connection on the Maestro Head from there, so if you run the radio remote and the Power to the Radio bumps off and on then the radio will come back up with the Slice up on the Maestro head and use a slice.
    Hope this helps
    Disregard my FLEX-6700 it will still show the YELLOW Disconnect BOX
    Bret
    WX7Y
