Callsign entry issue
Thank you, on a side note.
In PROFILES in the call sign entry. The call sign is mixed up in the brackets for the no call sign message. When a call sign is entered. I guess the formatting is not correct. And maybe eliminate the message if an actual call sign entered?
@Pat Joy I do not see this when I look at my profile. Are you using a mobile device? Can you post a picture of just that part of your profile so I can see what you are describing?
This happens in the “Who’s on line” selection at bottom of my discussions selection. Selecting profile from window.
You can see we’re it appears on my iPad. iPad has latest iOS upgrades. iPhone shows call sign in right place, but the enter none statement could be better positioned.
pat
I see what you are saying. Perhaps removing the '(enter "none"....' when displaying would be a better solution.
@Richard C - I removed the explanatory text. Let's see how that works out.
Thanks, that worked. I know it is a minor issue, but formatting is not trivial due to the wide range of devices and how they process the formatting. On a side note, my radio is almost back from the Flex Hospital. Thanks to all!😁
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
