settings on the flex6400m/6600m for fldigi
Download the Flex SmartSDR RigCAT XML files: https://sourceforge.net/projects/fldigi/files/xmls/flex/. For a 6600M, download the ones for slices A, B, C, and D. Put these files in a location where you can find them.
In fldigi Rig setup, select SmartSDR_SliceA for slice A, B for B, etc. Set the COM port to the correct port listed in SmartSDR CAT for the slice you want to use. Make sure you have the Use RigCAT checkbox checked. Click Initialize, then Save.
Go to the Audio tab in the configuration window and set the Capture device to be the appropriate SmartSDR audio device for your slice. Set the Playback device to DAV Audio TX.
fldigi needs a higher audio level than many other digital programs, so make sure you have the level set before you try to use it.
That should be all you need to do. I set up mine this way (6600M) and it works fine.
73 - David, AG4F5 -
Hi John,
When you set it up did you follow the instructions "Setting up FLDIGI" in the FLEX-6000 Signature Series - SmartSDR for Windows Software User’s Guide ? (Para 34.4.1 - page 131) https://www.flexradio.com/downloads/
I found the instructions worked without issue the first time, and I've been using it every week since.
Good luck !
Jim, WQ2H
Do not see a file that is rigcat xml in the link. Already have SmartSDR_SliceA in rig control. Rig is no following the software. i.e. when I change freq on the flex, it does not follow.
Here's a screenshot of my setup. Note the following:
1. There is no other program accessing the Flex slice that fldigi is accessing.
2. The baud rate fldigi must match the baud rate in SmartSDR.
3. I am using CAT for PTT. Not sure if DTR/RS will work.
I hope this helps. If not, I'm happy to get on your system via Teamviewer and help diagnose and correct your setup.
73 - David, AG4F
Mine looks the same. I am working somewhat. By that I am send and receiving . Made a few PSK 31 contacts. The logbook is not working. I have a lot to learn as I have been off digital for about 3 years to take care of my wife full time. She is in a much better place now. I had another ham offer to do the same yesterday and he fixed a few things. I am tied up today as I with the help of 2 local hams are going to put up a Gap titan vertical. Email me at kb4oif@cox.net .0
Hi I am trying to use a Raspberry PI with Raspbian to run the fldigi and to have it connect to the 6600M. Is that something even possible to do?0
The audio should work the same as any other non-Flex rig via phones and mic jacks. Rig control might be a problem. How were you planning to trigger TX?0
You are absolutely right. I think one option is to plug the Pi in directly to the USB hub of the flex. then you can use USB terms to trigger tx using WSJTX and other software that support USB triggering. But pure ethernet triggering seems elusive unless you use Windows or OSX/iOS. Something has to handle the cat over TCP0
If you’re not picky, you can disable rig control entirely, tune with the raidio controls, and use VOX to trigger TX. I have done that on other rigs when portable with a failed serial cable, but it would not be my choice for setting up my QTH. Running digi modes with SmartSDR and DAX is a much cleaner setup....0
Trying to get FLDIGi to work. I have Audio set right. I downloaded the Slice A xml file. Set Device COM5 baud 38400 1 Stop Bit. Checked CAT Command for PTT. Did Save and Close. When I click the CQ button I see the text on the screen but my 6400M doesn't go into TX.0
When I did it, I used FLRig to communicate with the Radio via a LAN connection. You may want to look into that as an option to using an XML file. It is actually less complicated.
@AB8YZ in SmartSDR CAT does it show that FLDigi is connected to that port? Look for the line starting with "Process". If it says none, then you have an issue in your Configuration settings.
As usual, posting screen shots really helps to diagnose the issue.
The Flex 6600 follows the mode selected in the pulldown window of FLDIGI. I guess this is as designed. When the Flex 6600 mode in the slice is set to CW as it follows the CW choice in the pulldown menu in FLDIGI and I am tuned to a CW signal the CW signal from FLDIGI is horribly loud and distorted. When it is set to DIGU following setting PKTUSB in the FLDIGI pulldown menu the CW signal is OK but then FLDIGI cannot copy and display the received CW signal. Anyone have any thoughts about what I am doing wrong?
- 384 Community Topics
- 643 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
