Select Transmit Profile?
same here on 6400 v30
Would be nice to know if the lost transmit profiles problem is due to a bug or to user mishandling...just to avoid spending hours and days trying to find the error....!!!0
One thing you can do is delete all unused and unnecessary microphone and transmit profiles. Helps eliminate confusion. You do not need many microphone profiles. I have three, Digital modes, Radiosport and AT2035. There are some defaults and Radiosport caned profiles. In transmit profile I have only one for SPE 2KFA, plus the Flex defaults. In my case the one transmit profile is all that is needed, because my SPE control app takes care of operational modes and power settings. In Global I have a bunch, they are band and mode organized. Just make sure that when building a global that the appropriate microphone and Transmit profiles are selected then save in Global. Then make sure you export it all to a memory location on your PC.0
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
