Select Transmit Profile?
2»
  • Steve G1XOW
    Steve G1XOW Member ✭✭
    same here on 6400 v3
  • Francesco Doenz
    Francesco Doenz Member ✭✭
    Would be nice to know if the lost transmit profiles problem is due to a bug or to user mishandling...just to avoid spending hours and days trying to find the error....!!!
  • Patrick
    Patrick Member ✭✭✭
    One thing you can do is delete all unused and unnecessary microphone and transmit profiles.  Helps eliminate confusion.  You do not need many microphone profiles.  I have three, Digital modes, Radiosport and AT2035.  There are some defaults and Radiosport caned profiles.  In transmit profile I have only one for SPE 2KFA, plus the Flex defaults.  In my case the one transmit profile is all that is needed, because my SPE control app takes care of operational modes and power settings.  In Global I have a bunch, they are band and mode organized.  Just make sure that when building a global that the appropriate  microphone and Transmit profiles are selected then save in Global.  Then make sure you export it all to a memory location on your PC.
