Select Transmit Profile?
same here on 6400 v30
Would be nice to know if the lost transmit profiles problem is due to a bug or to user mishandling...just to avoid spending hours and days trying to find the error....!!!0
One thing you can do is delete all unused and unnecessary microphone and transmit profiles. Helps eliminate confusion. You do not need many microphone profiles. I have three, Digital modes, Radiosport and AT2035. There are some defaults and Radiosport caned profiles. In transmit profile I have only one for SPE 2KFA, plus the Flex defaults. In my case the one transmit profile is all that is needed, because my SPE control app takes care of operational modes and power settings. In Global I have a bunch, they are band and mode organized. Just make sure that when building a global that the appropriate microphone and Transmit profiles are selected then save in Global. Then make sure you export it all to a memory location on your PC.0
- 361 Community Topics
- 620 The Flea Market
- 8.1K Software
- 43 SmartSDR+
- 6.3K SmartSDR for Windows
- 178 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 268 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 224 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 984 Third-Party Software
