wifi hotspot
David jewer
New user..just got a 6300. I live in an are without isp providers. I only have wifi thru my Flip phone used as a wifi Hospot. I want to use my Ipad to use with my radio via remote and on my home wifi. There is no way to connect the radio to a router or modem. Is there anyway to get the 6300 access via hotspot? I saw a couple devices ( wifi to ethernet adapter) but not sure if that would work. Any help or suggestions would be appreciated. Thanks. David
ok sounds like a great possability..let me checkitn out..thank you0
Here is something you may want to look at. It gives you Internet without using your cell phone. One of the hams I know uses one, to run an IRLP node. Like you, where he lives there is no other options for internet.
It gives you both wired and wireless connections, so you could just plug your Flex into it the same as with other network routers.
Router Hotspot ZTE MF288 4G LTE GSM
ZTE MF288 Turbo Hub is an LTE modem with connections for up to 20 Wi-Fi devices such as smartphones, laptops and tablets simultaneously plus four wired connections via Ethernet without sacrificing speed. The 3000 mAh removable backup battery ensures a reliable Internet connection so conference calls can carry on and data stays protected – even in a power outage. ZTE MF288 mobile Internet device can be used anywhere where there is a power outlet and a cellular signal. Just plug it in and everyone is good to go. ZTE MF288 LTE Smart Hub keeps everyone connected on the ultra-fast 4G LTE network as if they were all in the office.
- 650 The Flea Market
- 152 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
