Maestro Waterfall missing TX label Slice A B
Toffy
Toffy Member ✭✭
Missing activ TX Label under slice A B on the waterfall.
I have two options for observing the display. either I look at the top left / right scale with frequency display and active TX or I look at the waterfall, which I think most people do.
Big disadvantage, you don't see the active TX there, so you have to look back again at the top of the scale whether A or B is active. Sorry that I can't tell on the waterfall whether A or B is active, which makes me sometimes  confuse..
Well, i have two eyes but i want to look straight. It would be desirable if the active TX icon were placed under the A or B slice.
Can you do that?
  • KL4QG
    KL4QG Member ✭✭
    edited June 2020
    Can you take a picture please....
    Joe
  • Toffy
    Toffy Member ✭✭
    edited June 2020
  • Tim - W4TME
    edited June 2020
    The Maestro and M models radios do not clutter the panafall display with a TX indicator.  The TX indicator is what you circled.  This is not something that we would be inclined to so as we want to keep the panafall display as clear as possible.
  • KL4QG
    KL4QG Member ✭✭
    edited June 2020
    Thank you =Hans,,,
  • Toffy
    Toffy Member ✭✭
    edited June 2020
    ok, understandable if you do not want to overload the display with additional icons, but maybe it would be helpful to color-code or underline the TX active slice. Any identification would be desirable. Thank you.
  • Uwe - DK3WW
    Uwe - DK3WW Member ✭✭
    Hi,
    Another possibility would be to color the background of the TX slice letter in red... HW?
    73! Uwe
    DK3WW
  • Toffy
    Toffy Member ✭✭
    edited October 2020
    Maybe I'm not alone, but I have to be very careful not to call on the wrong slice because the TX assignment is missing on the waterfall. That makes me crazy. This can´t happen with the Smart SDR because the assignment is clear there. Sometimes I wish to have the screen separate side bei side, then the waterfall is very narrow but better assigned to the TX than waterfalls one above the other.
    Toffy dj6zm
