SmartCAT 3.1.12 - Com port selection
N5NHJ
Member ✭✭✭
The selection of both the Client COM port and CAT COM is not available anymore.
It seems the COM port is automatically selected by the software.
The latest SmartSDR CAT User Guide (3.0.19, 4/25/19) still shows both ports as selectable.
Is this something that just changed in the software or there is some configuration somewhere?
Max,
In the SSDR CAT ADD port or Edit port, right click to bring up the and option for 'Advanced' ( & a warning popup ).
AL, K0VM
How do you know this magic...?
It worked, thanks!0 -
It's in the SmartSDR CAT User Guide.1
Is this different that version 2.4.9?0
Yep, I found it!0
Also fix your Computers registry. Best way and easiest is to get a computer maintenance application, such as Clean my PC. I think there are others also.0
Registry? I don't need to fix the registry, it was just about discovering a feature of SmartSDR CAT I wasn't aware of because I didn't read the manual carefully.0
Windows works better if you pay attention to the registry, you might be surprised at what you find. I gained much better reliability from making sure that the registry is running correctly. Mostly pertaining to comp port registry. Just a suggestion.....0
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 331 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 777 Maestro
- 42 FlexControl
- 730 Genius Products
- 253 Tuner Genius XL
- 85 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
