SmartCAT 3.1.12 - Com port selection
N5NHJ
N5NHJ Member ✭✭✭
edited June 2020 in SmartSDR CAT
The selection of both the Client COM port and CAT COM is not available anymore.
It seems the COM port is automatically selected by the software.
The latest SmartSDR CAT User Guide (3.0.19, 4/25/19) still shows both ports as selectable.
Is this something that just changed in the software or there is some configuration somewhere?
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited May 2020
    Max,
      In the SSDR CAT ADD port or Edit port, right click to bring up the and option for 'Advanced'  ( & a warning popup ).
    AL, K0VM
  • N5NHJ
    N5NHJ Member ✭✭✭
    How do you know this magic...?
    It worked, thanks!
    edited May 2020
    It's in the SmartSDR CAT User Guide.
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    edited May 2020
    Is this different that version 2.4.9?
  • N5NHJ
    N5NHJ Member ✭✭✭
    edited May 2020
    Yep, I found it!
  • Patrick
    Patrick Member ✭✭✭
    edited May 2020
    Also fix your Computers registry.  Best way and easiest is to get a computer maintenance application, such as Clean my PC.  I think there are others also.
  • N5NHJ
    N5NHJ Member ✭✭✭
    edited May 2020
    Registry? I don't need to fix the registry, it was just about discovering a feature of SmartSDR CAT I wasn't aware of because I didn't read the manual carefully.
  • Patrick
    Patrick Member ✭✭✭
    edited May 2020
    Windows works better if you pay attention to the registry, you might be surprised at what you find. I gained much better reliability from making sure that the registry is running correctly.  Mostly pertaining to comp port registry.  Just a suggestion.....
