PG-XL
James Kennedy-WU5E
Member ✭✭✭
I just purchase a PG-XL to replace my ALS-1306 I should have my PG-XL on the 20-21st. What are some the tips and do not do this can some the PG-XL users? Any comments are welcome.
Hi Jim -- I've had mine for about 8-9 months now. It's pretty loud so you might want to place it away from your chair. Since you will use SmartSDR or the Maestro to change operate/standby, no need to access the front panel. Use 220V if you can to get full power out. See you on Treasure Coaster net! 73 de Tom, N9GUN0
Don't curse your self to much for not buying it before, HI HI
Sorry only thing I could think of.
Wonderful AMP and built like a tank hope you enjoy it, the only AMP I have ever had that actually goes up in power as it warms up including Tube amps.
Bret
I've had my PG-XL since September 2019. Love it. A few suggestions...
Flex typically tests their amps before they ship. You may find that their test transceiver serial number is registered in your PG-XL (found in the Power Genius XL Configuration App under FlexRadio tab), so when you do your initial setup make sure you change this to the serial number of your Flex transceiver. If you don't do this, your Amp will not be recognized and you'll be wondering what the heck is wrong.
If you like to run modes that have long key-down transmissions, such as the Olivia modes, I recommend switching the Fan Mode from Standard to Contest. (PG-XL Config App - 'Other' settings)
As as mentioned above, you may fine the fan noise a bit noisy, so proper placement may be a concern. Also you'll find when the Amp is on (Operational Mode but not yet amplifying), you will hear the fan running at its lowest speed. (The Amp is perfectly silent when put in the Standby Mode).
Enjoy
The amp fan noise is so loud, that I put the amp outside the shack and only operate it from the Utility (FW 3.4.10) with the radio type set as Kenwood (doesn't really matter but curious that they wouldn't have a setting for "Flex") I use 9600 8N1 for the baud. Maybe I could use 38400 baud, but don't know what difference it would make. I do have the LAN cable (use a shielded 5e or better wrapped around several 3" choke torrods
I have operated SO2R rtty at 1500 W - which is almost a continuous duty cycle - and the amp temp approaches 80 C - without difficulty or problems (we are at 9000 ft agl so the air density is lower resulting in higher amp temps)0 -
I copied and pasted KF4HR comment above about doing this below
If you are running a Flex this is why you didn't see a Flex listed. Go back to the PGXL install program and find your radio by following the instructions. If you did the above for some reason your network is not finding your amp, maybe a bad cable etc
James the only hitch I had is what KF4HR posted about clicking the tap to find your radio and not the test radio serial number showing. This hung me up for a few mins until I clicked on the drop down tab and when I did my radio showed and the correct serial #. Once I clicked this everything fell in place and I was done with the setup. I have had my PGXL for about 20 days now and not a hitch even did a firmware update on the amp the 3rd day I owned it ! Good luck and enjoy
After you put in Flex serial number in A and B you have to save in the PGXL Utility. On FT8, RTTY and CW you can use Meffa. When checked you have to transmit a number of times for it to zero in on the right bias. PA temps run 10 degrees lower or more. The drive needed will be be higher And that is ok. The temperature in the harmonic load will increase because the amplifier is operating in a less linear range. For SSB and any other mode that requires linearity the Meffa will/should not be use. I believe it is turned off when on SSB, AM and I am not sure for PSK as I don’t operate that. I put mine in an adjacent room or away from your position. It can be located anywhere even close to where your coax exits your home. I now have much less RF in my shack. Superb amplifier. I have had mine for about a year. Last tip I set a power limit for the Flex radio of about 50 so I don’t severally overdrive it by mistake. In general SS amplifiers don’t like being overdriven as I have heard years ago. 73 Bill W9JJB0
- 325 Community Topics
- 590 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 394 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 150 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 865 Genius Products
- 307 Tuner Genius XL
- 114 Antenna Genius
- 274 Shack Infrastructure
- 194 Networking
- 135 Contesting
- 715 Peripherals & Station Integration
- 135 Amateur Radio Interests
- 938 Third-Party Software
