Custom Interface Cables
Mike-VA3MW
Hi All
I am looking for people who make specialized interface cables on demand for those customers that require help.
As an example, you have an OEM radio like an FTdx3000 and you want to interface band switching to a PGXL. One end requires a HD15 connector and the other requires a DB9 for the required band data switching. (Not the same issue if you use a Flex Radio with the PGXL).
I know they are out there, but I have no clue. If you know of such a business, can you let me know so I can share it with others.
This is one that I know of. https://redcab.com/home.php
Many thanks, Mike
Many thanks, Mike
If you talking about amplifier interface cables Dan makes them for SPE Expert Amps and maybe for others .
Order INTERFACING CAT CABLES
Contact Dan Tassell, KC5PCB
kc5pcb2@att.net
Just around the corner from you is Infinite Cables - Depending on what you want. Your request was very vague.0
Thanks Stan. Yes, Infinite is 5 minutes away. They have a lot of my money!
I have updated my description. 0
- 354 Community Topics
- 618 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 175 SmartSDR for Maestro and M models
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 25 Aurora
- 218 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 759 Peripherals & Station Integration
- 979 Third-Party Software
