Install only the dax drivers needed?
Ross Slater
When installing smatsdr it would be nice to have an option to install only the dax drivers needed for your setup.
can you explain?
DAX is a part of Smartsdr. Only DAX is useless for you .
You cant use DAX with any other TRX then F6.
Chris
DAX and CAT alone are useful if you have a 6400M or 6600M.
[To explain: I use v2 and a Mac with my 6600M. I run all manner of digital programs to the existing slices on the 6600M front panel. The digital programs control the radio nicely using CAT (xCat) and I get the waterfall from JS8Call / WSJT-X, etc. Of course I also use dogparkSDR and SDR on Windows when or if I want or need them.]0 -
What would be nice is for DAX to be FIXED.
I still have to stop and restart DAX several times a day.
Let me explain, I use DAX audio RX1 and DAX Audio TX for both JTDX and Fldigi that's all. If I need more it would be nice to be able to add as needed. There is another program I was using but it does not play well with DAX. After browsing through all the previous threads it's been a problem for a few years. Program is Yaesu's Wires-x. No complaints just a thought.
The challenge is that DAX is not a driver that lends itself to be installed dynamically and SmartSDR DAX can connect to radios that have from 2 to 8 slices. So we install all the necessary drivers to accommodate any model of FLEX-6000 you use without having to load drivers and reboot your PC and or unload drivers when you are done, and reboot your PC..1
Thank you for the response makes sense.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
