Install only the dax drivers needed?
Ross Slater
Ross Slater Member ✭✭
edited May 2020 in DAX
When installing smatsdr it would be nice to have an option to install only the dax drivers needed for your setup.
  • Chris DL5NAM
    Chris DL5NAM Member ✭✭✭
    edited May 2020
    can you explain?
    DAX is a part of Smartsdr. Only DAX is useless for you .
    You cant use DAX with any other TRX then F6.
    Chris
  • Ted  VE3TRQ
    Ted VE3TRQ Member ✭✭✭
    edited May 2020
    DAX and CAT alone are useful if you have a 6400M or 6600M.
    [To explain: I use v2 and a Mac with my 6600M. I run all manner of digital programs to the existing slices on the 6600M front panel. The digital programs control the radio nicely using CAT (xCat) and I get the waterfall from JS8Call / WSJT-X, etc. Of course I also use dogparkSDR and SDR on Windows when or if I want or need them.]
  • Pat N6PAT
    Pat N6PAT Member ✭✭
    edited May 2020
    What would be nice is for DAX to be FIXED.
    I still have to stop and restart DAX several times a day.
  • Ross Slater
    edited May 2020
    Let me explain, I use DAX audio RX1 and DAX Audio TX for both JTDX and Fldigi that's all.  If I need more it would be nice to be able to add as needed. There is another program I was using but it does not play well with DAX. After browsing through all the previous threads it's been a problem for a few years. Program is Yaesu's Wires-x. No complaints just a thought.
    edited May 2020
    The challenge is that DAX is not a driver that lends itself to be installed dynamically and SmartSDR DAX can connect to radios that have from 2 to 8 slices.  So we install all the necessary drivers to accommodate any model of FLEX-6000 you use without having to load drivers and reboot your PC and or unload drivers when you are done, and reboot your PC..
  • Ross Slater
    edited May 2020
    Thank you for the response makes sense.
