SDR 3.1.11 Install Went Very Well
It is looking for the default sound device in your computer. Make sure it is enabled and selected as default. In the future it may be good to download the Flex file manager that saves all you Dax and Cat settings so you can just restore them anytime.
.https://www.flexradio.com/downloads/smartsdr-settings-file-manager/?_ga=2.186550251.376251628.158688..
OK, I fixed the problem but doing a v3.1.11 complete re-install. All seems normal now. Should have done that 1st.
Nothing to see here. Move along.
73!
Thanks for that Bill, I will keep a copy of this on my desktop.
BTW: My update was smooth with 3.1.11
6600 and Maestro A.
Same here! upgrade with no issues so far!
Thanks!0 -
I'm a bit confused about this latest update, specifically relating to the corrected issues relating to SD Card Corruption. Is this SD Card an option or something internal? I've never used a SD Card with my 6700.
It is internal and not something you should normally remove unless Flex tech support directs you to.
Len, KD0RC
The SD card is in a slot on the board in the radio. There have been a number of radios being effected.0
Just trying to update my 6600 via the Maestro, the download is estimating a very long time, past upgrades have flown through, I'm in the UK.
'Download (Step 1 of 4): 104min remaining' :-(0 -
104 minutes?
yes correct, some 22 mins later it is still displaying 65min remaining, time to hit the cancel and go to bed0
In the end the install went well. Only glitch was that when the firmware load got to 100% the radio hung. I reset the radio (held the power switch till it shut down) then powered down the DC power, reapplied DC power. At this point restarted radio and SmartSDR and all was well. As for the v3.1.11 software I finally broke down and purchased this new version, upgrading from v2.6.1. After some time, operating with new version, I was happy to see one problem that was at least 98% corrected. Also the ability to run the remote operation (I realize that this was available in the original version of v3) from I pad is much appreciated. Still exploring this new version, but I have a sense that DAX and CAT are improved. Some things that would be very nice addition, would be adjustable audio DSP filtering. I currently use an outboard device and and although it works extremely well, it has certain design limitations that, are internal and are in regards to RF susceptibility. Also selectable audio muting on transmit would be a good addition. Feedback is an issue if one accidentally leaves the monitor function on when switching to speakers from earphones. Ability to switch slices A<>B Would be nice with out third part apps. Less reliance on third part apps, with some of the new modes built in as it is done for the iOS version.
Bill, Len, thanks for the info. I wasn't aware it was in there.
Version 3.1.11 download completed and upgraded end to end successfully, thank you Flex0
I have a 6300 with ATU. All went quick and no issues. After every new update, it's a good idea to shut down both Flex and pc and restart. I have done this since day one without any problems what so ever. Thank you Flex, you're still the best in my book... I am looking for a decent price on a Flex 6700. Anyone reading that has one for sale please message me.0
Can anyone please advise. Does the 6300 series have an SD card inside also? Thank you. 730
Yes, all 6000 radio do1
I did the update ALL works great !!0
Smooth install, both F6700 and Maestro V1.
Upgraded to 3.1.11 yesterday. No problems detected. Good update!
I'm glad you got it figured out. If you do get stuck on something like that in the future, posting here isn't a bad place to go for community help. If you need an official support response though, make sure that you open up a helpdesk ticket at helpdesk.flexradio.com. Happy Flexing.0
I noticed the update was slow on my M model this morning. This is most likely related to the volume of folks downloading it, but we'll be looking into this. Thanks for the report.0
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
