Interesting time using the NR
Bill -VA3WTB
Member ✭✭✭
last night I tuned into a friend broadcasting his Anan 7000 DLE over u tube. 80 meters.
At some point he turned on his NR2 in order to lessen the static on the band. Because I could hear his audio from his radio well I heard the difference.
I decided to turn on my NR. As usual the Flex NR made signals very dull without any mid ranges in peoples voices. So I started trying some settings. I set the NR between 6 and 10 on the slider. Then I used the RX EQ to increase the upper frequencies to compensate for the NR loss. I turned up the slice audio gain and just listened.
It was really nice, All the voices were clearly heard and the band noise went down a lot. And it closely compared to the Anan, if not smoother. The Anan had a lot of pumping and wind sounds although the peoples voices were good. The Flex had none of those sounds in the background and no pumping. I also found that if a signal approached S9 the NR performed it's best.
I think I am re thinking the use of the NR, I have been impressed, somewhat surprised.
Give it a try and see if you can make it work as well as I have?
2
Thanks for the info Bill. I'll give it a go on 80 this evening. That's when a lot of crud shows up in my neighborhood. James WD5GWY0
Bill - you are exactly right! I had kind of given up on the NR function on my new 6400 due to the muddy sound. I just set it to 24 and bumped the bass down a little and turned the vol up to compensate and it is really helping on 40 M right now. Thanks for the tip!
Len, KD0RC
I try NR and NB last night while using CW. It didn't work very well. Loud signals anywhere in or near my panafall view screen were telegraphed into my slice. I've experienced this many times before. But I forgot, (like oh yeah, that's why I don't use them). The WNF does the same thing. If Flex can find a way to activate the NR and NB based on data inside the Slice only, it would work better.0
I didn't try CW, I was on SSB. So looks like it does not work so well on CW.0
It works! On 75m this morning with a persistent frying noise, maybe powerline across the band. NB and WNB don't touch the noise but NR + EQ is doing a good job making copy much more pleasant.
Great suggestion.
Tried it on our local 75M net this morning on our HF NET with Bill's settings and it worked from a 60 over S9 1.5KW signal a quarter mile away to a S3/S4 signal and with the settings NOT over 7 but with the RX EQ range set so the voice audio sounded the same as with the EQ and NB OFF.
Thanks Bill for the heads up
Bret
WX7Y0 -
Hi Bill,
Just a quick update. I've been playing with the receive EQ settings and Noise Reduction settings and it does help clean up some of the crud generated by neighbors A/C unit enough that I can enjoy the audio much more. Thanks for the tip!
Now, just come up with some magic setting for the ANF!!
- 328 Community Topics
- 593 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 396 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 160 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 438 Remote Operation (SmartLink)
- 135 Contesting
- 723 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 942 Third-Party Software
