Antenna Setup for 4 slices in Flex 6600
artimus
I have the following antennas:
Ant 1 - 3 element triband beam 40 (1 ele) -20-15-10 m
Ant 2 - 3 element 6 meter beam
XVTR B - 2 meter transverter on a VHF beam
I am trying to set up 4 slices as follows:
Slice A - Ant 1 RX Ant 1 TX Band: 40 meters
Slice B - Ant 1 RX Ant 1 TX Band: 20 Meters
Slice C - Ant 2 RX Ant 2 TX Band: 6 meters
Slice D - XVTR B RX XVTRB TX Band: 2 meters
Screen Shots are shown at the following links:
https://www.dropbox.com/s/ur1etfcpt6msrxj/First%20Screen%20Shot.jpg?dl=0
https://www.dropbox.com/s/jn1gljobpwiublq/Second%20Screen%20Shot.jpg?dl=0
When I attempt to set Slice C to Ant 2 it changes Slice A and B RX to Ant 2
It won't allow independent RX ant selection on Slice C without always changing RX selection on Slice A and B to match Slice C.
My objective is to listen to these 4 bands concurrently.
How can I set it up so slice C RX antenna is independent of Slice A RX ant and Slice B Rx antenna?
The only reason I can think that this won't work is because the XVTR is using one of the SCU's and has priority. Maybe it's not possible to do this without 3 SCU's.
Jeff
KD6RC
Jeff
KD6RC
Hi Jeff
If I read this correctly, Slice A and B are ok.
Your challenge with Slice C and D is that you can't XVTR B at the same time as using ANT 2. It is one or the other.
The best you can do is have XVTR B TX only active since once you go into TX it will switch ports.
Jeff,
What you are trying to do would require 3 SCU's, but you only have 2..
You might be able to do what you want if you use a VHF diplexer on Ant2.. Common port the to ANT 2 and 2m on the VHF port and 6m on the other port ?? Or a HF-6m diplexer on ANT1 with 3 slices ( 1 SCU) and 2m stuff on the XVTR 2 ( the other SCU )
AL, K0VM
Hi Michael,
If I want to monitor 2 meters at the same time....it appears this is only possible if I use Ant 1 on Slice C to receive on 6 meters. Then the second SCU is devoted to 2 meters only....I guess.
If I want to transmit and receive on 6 meters, I will have to close Slice D to use Ant 2..the 6 meter beam on Slice C.
Jeff
Hi Al,
Thanks for the ideas. I will see what I have in the parts bin and try something.
Jeff
Comet CF-360
AL, K0VM
- 378 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 260 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
