QO100 Fldigi - SSDR
Roland HB9VQQ
I just finished setting up my QO100 ground station. Downlink is between 10489.500 - 10490.00 MHz. I have a UP/Down Transverter connected to XVTA. RX/TX all working fine. Now I wanted to use FLDIGI and found the DL Freq. is not displayed, it still shows the QRG of the last selected HF Band. Using RigCat. FLDIGI PTT, TX/RX all working fine, just the Frequency which is not picked up.
Is this a known issue ?
Same problem with OmniRig. What is the CAT command to read the frequency from the Transverter ports ?0
Hi Roland, can you give me more details on your transvertersolutuon? I am nterested to to setup a qo100 setup like yours Tnx Don0
Hi Don,
I made a drawing to show the schematic overview of my setup. The extra RX with the Afedri SDR is entirely optional and only required if you wanna have full duplex capability.
Transverter is from the Netherlands.
http://www.hfprints.com/pe1cmo/rc_images/pe1cmo_products.pdf
Roland0 -
It seems a really well done setup, the netherland guy provides good products Thanks Ik2egl0
Hi Roland
I am in touch with Steven for xvtrto use it from flex
Now my question for you is how you get down digital to fldigi.
Do you receive with sdr console and open a virtual cable to fldigi?0 -
Sorry for the late response have not noticed your question until today. Yes correct I receive through SDR Console and feed the RX Audio to fldigi with the help of VB-Audio virtual cable.
- 352 Community Topics
- 615 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 412 SmartSDR for Mac
- 267 SmartSDR for iOS
- 250 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 212 FLEX-8000 Signature Series
- 922 Maestro
- 895 Genius Products
- 324 Tuner Genius XL
- 116 Antenna Genius
- 284 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 974 Third-Party Software
