QO100 Fldigi - SSDR
Roland HB9VQQ
Roland HB9VQQ Member ✭✭
edited June 2020 in Third-Party Software
I just finished setting up my QO100 ground station. Downlink is between 10489.500 - 10490.00 MHz. I have a UP/Down Transverter connected to XVTA. RX/TX all working fine. Now I wanted to use FLDIGI and found the DL Freq. is not displayed, it still shows the QRG of the last selected HF Band. Using RigCat. FLDIGI PTT, TX/RX all working fine, just the Frequency which is not picked up.
Is this a known issue ?
  • Roland HB9VQQ
    edited April 2020
    Same problem with OmniRig. What is the CAT command to read the frequency from the Transverter ports ?
  • ik2egl
    ik2egl Member ✭✭
    Hi Roland, can you give me more details on your transvertersolutuon? I am nterested to to setup a qo100 setup like yours Tnx Don
  • Roland HB9VQQ
    Hi Don,
    I made a drawing to show the schematic overview of my setup. The extra RX with the Afedri SDR is entirely optional and only required if you wanna have full duplex capability.
    Transverter is from the Netherlands.
    http://www.hfprints.com/pe1cmo/rc_images/pe1cmo_products.pdf
    Roland
  • ik2egl
    ik2egl Member ✭✭
    It seems a really well done setup, the netherland guy provides good products Thanks Ik2egl
  • ik2egl
    ik2egl Member ✭✭
    Hi Roland
    I am in touch with Steven for xvtrto use it from flex
    Now my question for you is how you get down digital to fldigi.
    Do you receive with sdr console and open a virtual cable to fldigi?
  • Roland HB9VQQ
    Sorry for the late response have not noticed your question until today. Yes correct I receive through SDR Console and feed the RX Audio to fldigi with the help of VB-Audio virtual cable.
