Solid red light when transmitting — is the PA bad?
Joe KK9TT
My power button turns red when transmitting or tuning at any power, even the lowest. Checked voltage at incoming power poles, cables to power supply only about a foot long, did factory reset. No joy.
Is my power amp a goner?
Any ideas or do I have to bring it to Austin (we're traveling nearby) if Flex is even open during this virus problem.
Thanks in advance for any help.
Joe KK9TT
Joe KK9TT
Power button green in RX and red in TX is correct.0
On my 6300, when I transmit the power button turns red. It's supposed change red then back to green in RX????? unless we are not understanding you correctly? Can you please go into a bit more of details. I think we are missing something.0
Hey John
Now would be to page through 2 manuals. The software manual and the hardware manual. We hide a lot of secrets there!
You can find them on the Flex web site in the download area.
Here are some you'll like:
6.6.1 Chart for Indicator Color Codes
SOLID BRIGHT RED: Transmitting on PA
SOLID ORANGE: Transmitting on XVTR port with low power
SOLID DIM RED: Transmit engaged, but transmit interlocks are not ready.
SOLID PURPLE: Radio is performing a software update
SOLID GREEN: Radio is in receive mode
FLASHING RED: Flashing three blinks indicates radio software is not running
FLASHING GREEN: Radio is booting or loading firmware
FLASHING WHITE: Radio is performing a reset to factory defaults
OFF: Radio turned off, oscillators are off.
Just kidding on the secrets. LOL
Mike va3mw
From the hardware manual:
• FLASHING GREEN: Radio is starting or shutting down
• SOLID GREEN: Radio is in receive mode
• FLASHING RED: See Error Conditions below
• SOLID BRIGHT RED: Transmitting on PA
• SOLID DIM RED: Transmit engaged, but transmit interlocks are not ready. Refer to the SmartSDR documentation for description of the transmit interlocks.
• SOLID ORANGE: Transmitting on XVTR port with low power
• SOLID PURPLE: Radio is performing a software update
• FLASHING WHITE: Radio is performing a reset to factory defaults
• OFF: Radio is off
You made me look, never really took note before.0
Well, I got schooled. My Flex is hidden away under, way under, a desk and to turn it on or off I feel for the power button — can’t see it — and turn it on or off. Never knew it turned red when transmitting until I crawled around down there recently to clean things!
Yup, time to reread the manual.
D'oh! Thanks, folks.
during transmit mine turns RED and when switch back to recieve it turns Blue ( GPSDO installed )
Jim/WU5E0 -
While transmitting, mine emits small swirls of blue smoke that surround the red button, while also making a faint roaring hum of modulating intensity, like that of a warp drive engine.
Perhaps I have a slow plasma leak in one of the field correlation magnets?
Humph, perhaps another glass of Vino is in order...
3 -
A little early for April Fool's posting...0
Sounds like you need to check the hydrocoptic marvelvanes and recalibrate the grammeters.1
obviously a bad Flux Capacitor...
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
