MAESTRO PROBLEMS
I am only addressing this one particular problem with my 1yr old Maestro. Most of the time when this occurs its locks up and only holding down the power switch and restarting in order for it to work again. Today when this happened I was able to change freq and all seemed ok except for the big gray box saying "radio in use, unable to connect" and when I touched OK it shut down and restarted. I was also running the 6600 in my cave and she was running just fine. Both MAESTRO and my PC in my cave have been running just over 24 hrs when this error popped up.
Any ideas as to what happened ?
Which SSDR version are you using?0
SRI, forgot to mention that. Running 3.1.80
Is the Maestro connected via wifi or lan?0
wifi, PC on 5G, Maestro 2.4G. Also forgot to mention when Maestro is on the 5G it constantly keeps dropping connectivity. Live out in the sticks so practically no interference from others.0
OK, that is what I thought.
I have seen this before. What I think happens is that the data flow on the WiFi network is getting interrupted, which isn't a surprise at all. The Flex Radios move data on the WiFi network that is very time sensitive. As operators, we can't handle our HF signals being very late (latency).
It could be that your router is buffering a lot of data and this is resulting in Maestro data being out of sync. (I'm sure Tim can explain further).
Since both devices are on WiFi, you have quadrupled the impact.
So, what can you do?- Try another WiFi access point
- See if you can get the radio LAN connected to the Access Point
- Reduce your data flow to the Maestro by sliding the FPS and RATE sliders in the Display tab (this will help a lot)
- Try not to use 2.4G since it is bandwidth limited
Hi Mike,
I dont understand what u mean by different "access point" ? Radio is the only thing connected to LAN
I usually have the FPS and waterfall set very low.
When I try the using 5G on Maestro it locks up every couple hrs and 2.4G seems to last longer. WIFI traffic here very low, 2 PC's and sometimes my laptop.0 -
Mike,
Your WiFi access point actually has more connections than you think, especially at 2.4G. Every other WiFi device may have traffic on the same channel, of which there are very few, and has to decide if that traffic is for you.
A neighbor that is streaming can wipe out your box.
Direct STP/SSTP cable connection is best with a double female and very short UTP cable at your radio side. This prevents noise pickup and also avoids a ground loop. Other option get a longer SSTP cable, cut so it reaches to both devices, and install a non shielded connector at each cut.0 -
Appreciate ur suggestion but as I stated I live out in the STICKS so very little WIFI activity except for my 2 PC's and laptop once in a while. Have no clue about STP/SSTP ? The whole point of getting a Maestro was so I can use it rather than laptop when I want to go sit outside and enjoy the outdoors. My conclusion is that the tablet being used might be a little on the deaf side ? The Maestro is about 15ft from router so I would ASSume theirs plenty signal strength ?
I switched the Maestro to 5G couple hrs ago and will let her run to see how long before she locks up.
TNX 4 ur input0 -
ok, I set the Maestro back to 5G and it pooped out 2hrs later, just a blank screen now. Put it back to 2.4g, and will see how long she goes
This issue has little to do with signal strength and everything to do with throughput. The Maestro (or any SmartSDR client for that matter), when connected to the radio via a WiFi link is streaming data in real-time. This is very different than watching videos where the data is buffered to overcome network latency and throughput deficiencies. Buffering data for a real-time process like making QSOs is not an option.
I suspect that your WiFi access point (router) is just not up to the task. For more information on this, I refer you to the HelpDesk article Reasons for Wireless Network Performance Problems.
What you may have to do is replace your WiFi router with one that is capable of real-time streaming throughput. WiFi routers and access points that are designed for the gaming market meet this criterion. I recommend getting one of the more recent AC2900 or AC3200 WiFi routers. Here is a link to the top gaming WiFi routers: https://www.techradar.com/news/the-best-gaming-routers0 -
Thanks to all of you for your suggestions. Guess I need to start fertilizing and watering my money tree which died yrs ago, maybe with good weather and LOTS of luck it can sprout a few bucks so I can buy a "gaming rated router" as Tim suggest. Being on fixed income suks! If anyone has one at a reasonable price I would be interested!
TNX again to all, N8AUM Vidas0 -
TNX Tim for taking the time for explaining and possible solution for my predicament !
73 N8AUM Vidas0
- 352 Community Topics
- 617 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 174 SmartSDR for Maestro and M models
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 23 Aurora
- 217 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 285 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 758 Peripherals & Station Integration
- 978 Third-Party Software
