FT8 problem on 60 meters
jim
I'm running FT8 on all bands except 60 meters. Using a 6500 and latest version of wsft-x. I have
looked at a lot of post about problems. When I go to 60M the freq on wsjt-x turns red and will
not allow transmit. I copy fine. Any ideas.
Try setting the high cut to 2500
Yes, 60M bandwidth must be less than 2.8 Khz so limit your TX bandwidth as necessary.0
Changing the high or low cut has no effect. I have tried everything that has been in all the posts
that I have read.
turn off 'split operations' in wsjtx....
this will keep wsjtx fro sending a change freq command during transmit
paul k3sf
You on 5.357 DIGU?
Go to File>settings>Frequencies, right click on an entry and insert the 60M frequency.
This is not a default supplied frequency setting.0 -
Thanks Bill. I had thought about that but had not change a freq. everything seems to be working
fine now.0
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 156 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 122 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 847 Genius Products
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 696 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 921 Third-Party Software
