FT8 problem on 60 meters
jim
jim Member ✭✭
edited August 2020 in Third-Party Software
I'm running FT8 on all bands except 60 meters. Using a 6500 and latest version of wsft-x. I have
looked at a lot of post about problems.  When I go to 60M the freq on wsjt-x turns red and will
not allow transmit.  I copy fine.  Any ideas.
  • Pat N6PAT
    Pat N6PAT Member ✭✭
    edited March 2020
    Try setting the high cut to 2500
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    edited March 2020
    Yes, 60M bandwidth must be less than 2.8 Khz so limit your TX bandwidth as necessary.
  • jim
    jim Member ✭✭
    edited March 2020
    Changing the high or low cut has no effect.  I have tried everything that has been in all the posts
    that I have read.
  • K3SF
    K3SF Member ✭✭✭
    edited March 2020
    turn off 'split operations' in wsjtx....
    this will keep wsjtx fro sending a change freq command during transmit
    paul k3sf
  • Rich McCabe
    Rich McCabe Member ✭✭✭
    edited March 2020
    You on 5.357 DIGU?
  • Bill W2PKY
    Bill W2PKY Member ✭✭
    edited March 2020
    Go to File>settings>Frequencies, right click on an entry and insert the 60M frequency.
    This is not a default supplied frequency setting.
  • jim
    jim Member ✭✭
    edited March 2020
    Thanks Bill.  I had thought about that but had not change a freq.  everything seems to be working
    fine now.
