Dear Flex, Please fix VOX ASAP
Sergey, I can appreciate your frustration when there is a feature of the software that isn't working properly for you. As noted by the status of this post, the determination of the problem which is the first step in fixing the issue is in progress. Additionally, this issue does have a high criticality.0
Hi Tim,
Hopefully above VOX issue will be fixed in the next SW release.
I would assume that issue is not isolated to me me only.
Here is another find during ARRL DX SSB contest.
Please see video and let me know if is this something I am doing wrong, is it VOX issue related to above, is it known issue and you are working on it or is it a new issue that no one reported yet.
Radio 6600 with Ver 3.1.8
https://drive.google.com/open?id=1RXZ9YokkGuWzrrnn2wtMFWr_g8YsR7sf
Sergey, KN7K0 -
You have DAX and VOX enabled at the same time which is exacerbating the VOX issue that I mentioned above.0
I'm a new 6600 user and always used VOX on my Yaesu 2000 and 5000 with no issues. This weekend during the CQWW SSB I plugged in my RadioSport headphones and all was well for a couple of hours. Then intermittent drops in transmission started occurring. I tried to adjust the levels and delays but it only got worse. I had to switch to a hand switch (thank goodness I had one in my junk box) and was able to complete the contest. However, I have no confidence in VOX at this point and I've used it with no issues for years on my two previous Yaesus with no issues. Apparently this is a known issue and this is a BIG deal for me working contests with really fast exchanges. Also, addressing why delay is set so low, delay has to be set low so the transmitter isn't held on while the other party is already coming back with a quick exchange. It's that fast.
Jim AK4I0 -
yes, i used VOX all my life on previous radios without any issue.
I had to purchase a foot switch for Flex6600 to avoid drops.
Hopefully next year (???) we will see some update with bug fixes
Sergey, KN7K
An idea- I wonder if a future version of SSDR could incorporate a syllabic VOX. It would be a nice addition for SSB operators.
Sergey , did you read Tim saying to turn Dax off while in SSB ? My 6600 does the same as yours if I have Dax on .
Ed N5DG
my vox occasionally unkeys after you start talking, figured it must be a bug, at first I did catch DAX on but learned about that and keep it off, but still does unkey on occasionally, which is aggravating!
Ed, I have a video that I shared with community 1.5+ years ago, it shows VAX stuttering without DAX enabled.
If needed I can reupload it again.
I was hoping that bug #7724 would be addressed in 3.2.31 release, but unfortunately after all this waiting and hopes, it is still broken! I tested it today, same as before - UNRELIABLE !
Sergey
Here is the video from year ago with DAX off.
By the way, for contest like WPX, i have to have DAX ON to play prerecorded messages, so while DAX ON or OFF does not affect VOX defect, I need it ON for Contest to play CQ and follow up with VOX for a serial number.
VOX does not drop my TX with settings 20+, but this is too much delay to complete QSO
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
