Flex 6600m
K6ANP
Flashing red power button when I operate the push to talk on the mike or when I hit the dit or dah on the paddle. When I first turn on the radio the power button the light is green and stay that way until I attempt to transmit. The radio receive okay. This is a brand new radio right out of the box received it yesterday. Any help is appreciated Len, K6ANP I should have added after the power button flashes red a few time the radio shuts down
My first thought is the power supply has an insufficient current rating. What is the voltage at the power supply connections on the back of the radio when transmitting?0
Len,
I am so sorry that you are having this happens, right when you want to smell that 'new radio' smell while working DX!
When the red light flashes, does the radio 'reboot' (ie, show the Flex Radio logo, etc.)?
Geoff is correct, low voltage can cause this. When the red light comes on, it will blink (the number of blinks gives us an error code that helps isolate the problem). How many times does it blink red?
Hi
In the Hardware reference manual in the downloads area, there is a manual that explains all the flashing lights:
The front panel of the 6400/6600 contains only the Power button and the radio’s backlights. The Power button is used to turn the radio on and off and is illuminated with a number of colors to indicate the radio’s operational state:
You didn't mention how many flashes.
• FLASHING GREEN: Radio is starting or shutting down
• SOLID GREEN: Radio is in receive mode
• FLASHING RED: See Error Conditions below
• SOLID BRIGHT RED: Transmitting on PA
• SOLID DIM RED: Transmit engaged, but transmit interlocks are not ready. Refer to the SmartSDR documentation for description of the transmit interlocks.
• SOLID ORANGE: Transmitting on XVTR port with low power
• SOLID PURPLE: Radio is performing a software update
• FLASHING WHITE: Radio is performing a reset to factory defaults
• OFF: Radio is off
One red flash: Fan malfunction
• Two red flashes: Software crash
• Three red flashes: Boot failure
• Four red flashes: Input power over voltage
• Five red flashes: CPU overcurrent
• Six red flashes: Input power under voltage
When the optional GPS Disciplined Oscillator is installed:
• SOLID AMBER: Radio is off, GPSDO is powered for stability
• FLASHING YELLOW: GPSDO is warming up
• SOLID YELLOW: GPSDO is “holdover” mode (has lost satellites)
• SHORT FLASH BLUE: GPSDO is locking
• LONG FLASH BLUE: GPSDO is in “hold phase” mode
• SOLID BLUE: GPSDO is locked
73, Mike va3mw
Put test power slider to 2 or 3 then press test button. This may give indication of failure due to higher PS drop in voltage. Use dummy load to test also. Make sure power cable is well seated. Make sure Load is on A port and Ant is on ant 1. Since a brand new radio, help desk ticket after above checks. 73 Bill0
Try with 0 W. Then with 10 W. Do you have the issue with 0 W? Then angage ATU. Then bypass ATU. See if this fixes it. It did for me when I had the exact same issue. Andy KU7T0
I found the problem. I have a wireless antenna switching system due to the long distance from the shack to the towers. The link between the wireless units failed and the switch at the far end grounds all the inputs to protect against lightning. That resulted in the radio shutting down instantly to protect it self. Once I restored the antenna switching link all is well! I thank everyone for the help. de K6ANP0
- 115 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
