CW Skimmer and Slicemaster
Jim
I'm running a Flex 6400 with DM780, WSJT-X, Log4OM, and FLDIGI. I have Slicemaster installed, but to be honest I don't see what it doing for me. I've still had to configure all of the above third party applications manually. Now I've downloaded CW Skimmer, and it doesn't even show up in Slicemaster, let alone get configured. I'm new to Flex and Slicemaster so Im quite sure that I'm the problem but I'm at a loss as how to get slicemaster to set up CW Skimmer. Any help would be appreciated
Cab you lost some screen shots of your SliceMaster Laubch and Sync screens1
Here they are
Jim,
Slice Master cant find the programs you have installed. Any chance you've installed them somewhere other than their default locations? If so, you'll have to manually edit the Slice Master config.ini file to tell Slice Master where to look.
--Don
They've all been installed in their default locations and everything is located on the same drive0 -
Jim.
I'd like to take a look at your Slice Master log files. If you have a minute, please send them to the email address you see when Slice Master starts up. Just navigate to
C:Users<your user name>AppDataLocalK1DBO
then right-click on slice-master and select 'Send toCompressed (zipped) folder'. This will create a zip file that you can then attach to your email. It might explain why your installed programs are not showing up in the launch menu.
--Don
Just sent the file0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
