SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
CW Skimmer and Slicemaster
Jim
I'm running a Flex 6400 with DM780, WSJT-X, Log4OM, and FLDIGI. I have Slicemaster installed, but to be honest I don't see what it doing for me. I've still had to configure all of the above third party applications manually. Now I've downloaded CW Skimmer, and it doesn't even show up in Slicemaster, let alone get configured. I'm new to Flex and Slicemaster so Im quite sure that I'm the problem but I'm at a loss as how to get slicemaster to set up CW Skimmer. Any help would be appreciated
Cab you lost some screen shots of your SliceMaster Laubch and Sync screens1
Here they are
Jim,
Slice Master cant find the programs you have installed. Any chance you've installed them somewhere other than their default locations? If so, you'll have to manually edit the Slice Master config.ini file to tell Slice Master where to look.
--Don
They've all been installed in their default locations and everything is located on the same drive0 -
Jim.
I'd like to take a look at your Slice Master log files. If you have a minute, please send them to the email address you see when Slice Master starts up. Just navigate to
C:Users<your user name>AppDataLocalK1DBO
then right-click on slice-master and select 'Send toCompressed (zipped) folder'. This will create a zip file that you can then attach to your email. It might explain why your installed programs are not showing up in the launch menu.
--Don
Just sent the file0
- 419 Community Topics
- 719 The Flea Market
- 229 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
