Can someone help me install and setup cw skimer on my PC via teamviewer ?
YG6HBC
Im jhon and my callsign YG6HBC. Please help me someone to setup my cw skimer with my Flex 6400 in my PC because im stuck try setup. If someone can help me, you can email me directly at: jhondenisinaga@gmail.com
Use SDR bridge or slice master. It’s practically plug and play.1
I agree with Ria. SliceMaster will handle pretty much everything for you.
Can you give me link download slicemaster and install tutorial ? Thank you.
I have download slice-master-6000-master.zip and not get any instalation file in folder. How tobe install ?
Just put the file somewhere, create a shortcut to it and run it.
There is no install package.
Brother, can you help me by setup for me via teamviewer ?
I have installed slice master but still not get cw signal in cw skimer waterfall
Like Rich said, click on
https://github.com/K1DBO/slice-master-6000/releases
then scroll down to the 'assets' section and open it. You'll see a link for
slice-master-6000-v0.10.7c.zip
click on it to download. After it down loads, open the zip then drag slice-master.exe to your desktop (or any other place you'd prefer). Double click on it. Windows will ask you to grant permission for Slice Master to access your network. You're done.
If you have any of the supported programs already installed, you can launch them from Slice Master's launch tab. When you launch a program, keep an eye on Slice Master's status line (bottom of the window). If Slice Master has any trouble launching your program, an error or warning message will show up there to tell you what's wrong. The most common problem is that the slice or panafall need a DAX or DAXIQ channel assiged to it. Or the channel needs to be enabled in the DAX Control Panel.
Good luck!
--Don
Ah, Don is here
You are in good hands now.
Just remember you do not start CWskimmer yourself. Slicemaster launches it for you.
When im start the slicemaster i got this error...see at attachment in red circle
When i open slicemaster and click cwskimer, it does not open and get error
You do not have your IQ stream turned on for that slice.
On the left go over to the left and set it for Dax IQ channel 1
Ok, its will like this ?
That should be a good start. I can see an IQ stream running on your DAX now.
I would restart SliceMaster and then under launch tab on SliceMaster set it up for Slice A. Then you can do it for other slice if you want later.
Its success but the last question. At cw skimer setting as Im give screen shoot at radio hardware type, which type must i choose, im using Flex 6400 signature series. Thank you.
Slicemaster sets that up for you so do not have to change it. You can adjust your waterfall settings to meet your preference.
At cw skimer setting as Im give screen shoot at radio hardware type, which type must i choose, im using Flex 6400 signature series and at cw skimer, i got cw signal but why im not get callsign decode in right side ?
Please help me, why im not get callsin or decode in right side ? I got cw signal but not see the callsign decode
Well restart everything. You should see dit's and dah's on the waterfall of skimmer like you do on your flex waterfall. Dont expect callsigns right away depending on what is being sent.
Thank you for your best help
Maybe you have enabled "blind mode" by accident when trying to get it work? See the picture....
- 690 The Flea Market
- 197 SmartSDR+
- 112 Aurora
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
