Can SmartControl and Multi-flex be used at the same time?
Rick N4RZ
Member ✭✭✭
I have a Flex 6600M and a Maestro. What I am curious about is whether or not it is possible to use Multi-Flex to run one client on the M front panel another and a second using SmartSDR that is controlled by a Maestro using SmartControl at the same time?
Hi Rick
Yes, you should have no issue doing that.
Give it a try and see how you make out.
Thanks Mike!0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 963 Genius Products
- 353 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
