Can SmartControl and Multi-flex be used at the same time?
Rick N4RZ
Member ✭✭✭
I have a Flex 6600M and a Maestro. What I am curious about is whether or not it is possible to use Multi-Flex to run one client on the M front panel another and a second using SmartSDR that is controlled by a Maestro using SmartControl at the same time?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Rick
Yes, you should have no issue doing that.
Give it a try and see how you make out.
Thanks Mike!0
