Can SmartControl and Multi-flex be used at the same time?
Rick N4RZ
Rick N4RZ Member ✭✭✭
edited February 2020 in FLEX-6000 Signature Series
I have a Flex 6600M and a Maestro.  What I am curious about is whether or not it is possible to use Multi-Flex to run one client on the M front panel another and a second using SmartSDR that is controlled by a Maestro using SmartControl at the same time?
    edited January 2020
    Hi Rick
    Yes, you should have no issue doing that.
    Give it a try and see how you make out.
  • Rick N4RZ
    Thanks Mike!
