Monentary drops in Audtio
James Kennedy-WU5E
Member ✭✭✭
Montentay drop in Audio? I'm hearing many reports of Audio drops all of sudden then it comes anyone have this issue? if so what did you do to fix it?
Jim
WU5E
Jim
WU5E
Jim, Are you speaking of received audio directly from radio? Or through pc or IOS DEVICE? Or is this tx audio? Dudley0
Same question was posted last week. If you are doing digital modes I have noticed the gauge reflecting slow speed maybe the cause. In my cause rebooting the cable modem / router resolves my issue.0
while I'm transmitting I hear from many people now.
Jim
wu5e
James, would you explain your operating set up?
Flex 6600 with Smart SDR version 3.1.8 with a ALS-1306 AMP and Mic is Heil 781 plugged in BAL
Jim
WU5E
What you could do is try the hand mic and see if the drop outs still happen. that would eliminate the 781 connection as the problem.
Also, your can listen to your own TX to see if you hear it. Set up a 2nd slce on the same freq as slice A, so open a second panadapter set TX transmit to xvtr on slice B. Listen on slice A
And try transmitting without the amp
Think I found it my grandson and turned the DEXP all the way up no more reports of the issues
Jim
WU5E
O f course, the DEXP can cause cut offs if it is set too deep. Remember though you will need to set it correctly or it will cause other TX problems as well. I don't ever use it myself. with a headset you shouldn't need it.
- 343 Community Topics
- 612 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 407 SmartSDR for Mac
- 266 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 374 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 199 FLEX-8000 Signature Series
- 919 Maestro
- 890 Genius Products
- 452 Power Genius XL Amplifier
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 749 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 971 Third-Party Software
