No TX-audio Maestro Remote
Hallo FlexFriends!
73 de SA7AKE Jonas
Im using Maestro remote with computer headset,
worked ufb for 15min then both RX audio and TXaudio stopped working in the middel of qso.
Disconected the meastro and RX audio came back but not TXaudio using VOX. Rebooted again and same thing worked for 5min then the same TXproblem.
Evertything else seems to be in order, working.
connected to LAN and PS
Loged in with PC-radio using the same headset works UFB.
See pic, what is the red square in lower right corner??
(in pic VOX is not enabled)
73 de SA7AKE Jonas
Does the mic's plug use separate plugs for RX and TX (MIC 2)?0
Hallo Steven! Yes separate plugs, mix 2. Strange that it Has worked two times after reboot. What is the red square?0
Try this.... Disconnect the headphones and power the Maestro down with a long-press, hold until all lights go out Boot it up and only then plug in the headphones. Btw. You should have a separate mic profile for use on your Maestro so that Settings you change when using your computer don’t change settings used on your Maestro. Double check your bias and 20+ gain buttons to see if they need changed for your particular mic. Mastering the Mic Profiles is part of getting maximum performance out of the FlexRadio.0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
