No TX-audio Maestro Remote
SA7AKE
SA7AKE Member
edited June 2020 in Maestro
Hallo FlexFriends!
Im using Maestro remote with computer headset,
worked ufb for 15min then both RX audio and TXaudio stopped working in the middel of qso.
 Disconected the meastro and RX audio came back but not TXaudio using VOX. Rebooted again and same thing worked for 5min then the same TXproblem.
Evertything else seems to be in order, working.
connected to LAN and PS
Loged in with PC-radio using the same headset works UFB.
See pic, what is the red square in lower right corner??
(in pic VOX is not enabled)
73 de SA7AKE Jonas
  • Steven WA8Y
    Steven WA8Y Member ✭✭
    edited January 2020
    Does the mic's plug use separate plugs for RX and TX (MIC 2)?
  • SA7AKE
    SA7AKE Member
    edited January 2020
    Hallo Steven! Yes separate plugs, mix 2. Strange that it Has worked two times after reboot. What is the red square?
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    Try this.... Disconnect the headphones and power the Maestro down with a long-press, hold until all lights go out Boot it up and only then plug in the headphones. Btw. You should have a separate mic profile for use on your Maestro so that Settings you change when using your computer don’t change settings used on your Maestro. Double check your bias and 20+ gain buttons to see if they need changed for your particular mic. Mastering the Mic Profiles is part of getting maximum performance out of the FlexRadio.
