Uncommandeed Maestro reboots
Maybe your battery is down
Chris0 -
connected to outlet.
Yuri0 -
Believe me and give a try !0
what i have to do, find new battery?0
no, remove your battery pack, charge it with a USB cable.
Maestro has 2 different batteries. One inside of the Tablet and one removable and this battery you can only charge if you remove.0 -
Understand. Never knew about that. Will try. Thanks!!0
I assume that once you were done the contest, the Maestro worked as designed?
Have you considered you had an RFI issue with RF getting into the DC of the Maestro and causing it to reboot?
Does it do this on any other bands?
i worked remotely, so no RFI issues in shack.0
Got it
Is it still doing it or did it only reboot during the contest? If it continues to reboot, I would recommend opening a support case as this is very unusual.
It continues to reboot. Firs i will charge batteries today as Chris described, since i never did that before. See if it helps
Chris, i have no batteries there
Does it only reboot when you’re using batteries? What if you’re using only the wall adapter that came with the unit?0
Mike he has no battery0
I have no battery, this why i was surprised when Chris mentioned about it. Always connected to outlet0
I had is behavior b4 a long time; i change battery pack and it was gone. Since that time i change after some weeks (also if i am not using the battery) and charge again.
I your case i dont know how you fix this. Hope Mike can give your a hint - before you have to send back to FRS.
Cross my fingers.
Chris1
- 375 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
