Remote On
Dan KG0AQ
I am having an issue getting the remote on port to work. Is it as simple as a dry contact closure on the port and enabling remote on in the menu? I have tried both and no joy. 6400 & V2.6.1
TIA! Dan
TIA! Dan
Are you doing a constant on switch or toggle? It needs to be always on at least with the 6500.
Latching relay. Or always on or off.0
Hi Dan
Yes. You ground the center conductor and while it is grounded, the radio remains on.
You also have to turn the feature on in SmartSDR called Remote On.
Mike0 -
And you have Remote on: Enabled on the Radio tab in Radio Setup?
Make sure you ground the center conductor to the ring or shield. I use a micro relay right at the RCA phone jack on the radio. I do this to isolate any ground loops in my station setup. Just a good lessons learned. If you are not sure, plug and unplug in a shorted phono plug to see if that works. If not, check the SW settings. If that still does not work, enter a trouble ticket.0
That is what I started with. A phono plug with alligator clips. Software setting is Enabled. I thought there might be something else to enable. I am out of warranty so I'll just live with it. Thanks,0
open a support ticket. There might a simple fix that doesn't require shipping the radio in.
OK, I have never sent in a trouble ticket but will give it a try.
Thanks,0 -
Also, you can't turn it on with the front panel push button, then turn it off by remoting it off (activating then deactivating the remote on circuit). I always start with flex 13.8vdc power completely off, the remote on circuit open. Next apply 13.8vdc power to radio. Then close the remote on contacts (latch the relay). It should enter startup cycle just like you push the front panel power button. Unlatch and it shuts down. If you touch the front panel power button, front panel takes over and it ignores the remote on. At least on my 6700.
two methods, 1. if you short the phono connector and have remote on enabled, applying power to the radio will turn it on, no need to press the front button. 2. with power already applied, using a relay to short / open the remote phono connection will turn the radio on and off as required. I use a google home/alexa enabled relay board to do this, and a google home/alexa controlled mains plus to control the power to the psu. remote power control for less than $25 (must have internet through)
Thanks for all of the advise! Tim told me that I am doing everything correctly. The port may have a electrical problem. He suggested sending it in for repair.
73 to all who chimed in!
I have a 6500 running SDR 2.6.1, latest version, that is exhibiting the identical issue. Looks like I need to file a trouble ticket as well.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
