Can I adjust CW weighing in SmartSDR ?
allenfr
Adjust CW weighing
Negative....not in SSDR...
Lou N2TU0 -
Lou is correct. To change the CW weight parameters for DX'ing and ragchewing I use a Logikey K-5 connected to the Accessory Connector on the back of the Flex. For contesting I plug the paddle directly into the key jack on the front of the flex so the keying speed selected in the N1MM+ software is the same on the paddle.0
For future reference, this is item # 131 in the feature enhancement database2
Wondering if maybe the first step could be to just enable the Flex API so 3rd party programs can tweak the Winkeyer settings?
For example, the N3FJP (ACLog) CW Setup Form has a Winkeyer keying option which can be connected to a SmartSDR CAT Winkeyer. CW weight and other details are controlled in the N3FJP Winkey setup GUI, so if the Flex API accepted those parameters we would be in business.
Has any further work been done on this item #131?
Does anyone know if some progress on these suggestions?0
None that I know of. It was requested a llloooonnnnnggg time ago!...Hi Hi
Lou N2TU0
- 634 The Flea Market
- 134 SmartSDR+
- 198 DAX
- 42 Aurora
- 956 Maestro
- 298 Shack Infrastructure
- 210 Networking
