Can I adjust CW weighing in SmartSDR ?
allenfr
allenfr Member
edited October 2019 in SmartSDR for Windows
Adjust CW weighing
  • N2TU
    N2TU Company Adviser ✭✭
    edited March 2018
    Negative....not in SSDR...
    Lou N2TU
  • John - AF3K
    John - AF3K Member ✭✭
    edited July 2017
    Lou is correct. To change the CW weight parameters for DX'ing and ragchewing I use a Logikey K-5 connected to the Accessory Connector on the back of the Flex.  For contesting I plug the paddle directly into the key jack on the front of the flex so the keying speed selected in the N1MM+ software is the same on the paddle.
    edited October 2019
    For future reference, this is item # 131 in the feature enhancement database
  • John - AF3K
    edited April 2019
    Wondering if maybe the first step could be to just enable the Flex API so 3rd party programs can tweak the Winkeyer settings?
    For example, the N3FJP (ACLog) CW Setup Form has a Winkeyer keying option which can be connected to a SmartSDR CAT Winkeyer.  CW weight and other details are controlled in the N3FJP Winkey setup GUI, so if the Flex API accepted those parameters we would be in business.
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    edited April 2019
    Has any further work been done on this item #131?
  • tparish
    tparish Member ✭✭
    edited October 2019
    Does anyone know if some progress on these suggestions?
  • N2TU
    edited October 2019
    None that I know of. It was requested a llloooonnnnnggg time ago!...Hi Hi
    Lou N2TU
