RJ-USB6000 Desperately Needed WTB
Dawg Fan
I desperately need the Ameritron part number RJ-USB6000 to interface my 6500 to the ARI 500 connected to my ALS 1300 amp. These cables are not in stock at MFJ nor HRO. If you have one surplus to your needs please contact me at N5TF at Yahoo don't com.
I ordered one a week ago but, as you said, they are back ordered.0
I called MFJ and they don't know when more may be produced.0
easy to make .. i use it with my 6400 and als-1300 .. you need this cable ..
Here is the cable mapping:
FTDI Pin 2 Orange to ARI Pin 7 Brown/White
FTDI Pin 3 Yellow to ARI Pin 6 Green
FTDI Pin 4 Green to ARI Pin 5 Blue/White
FTDI Pin 5 Brown to ARI Pin 4 Blue
FTDI Pin 10 Black to ARI Pin 1 Orange/White
take any cat 5/6 network cable .. cut off one end .. connect as shown above ..
3 -
Thanks0
Looks like an opportunity for Flexradio!0
Stu/Anyone - do you recall the settings for the USB Cable in Smart SDR?
I made mine BCD and it seems to work fine.
bcd is right .. glad you got it going ..
Thanks for your help.0
Ameritron has just notified me that they have shipped the RJ-USB6000 cable to me.0
I can report that the RJ-USB6000 cable works as advertised. That cable and the ARI-500 gives you full auto band switching. You will also need an RCA cable from the TX1 jack on the Flex to the Relay jack on the amp, as well as an RCA cable between the Flex ALC jack and the ALC Jack on the amp. I did find out that the Default TX profile does not activate TX1 so select SO2R or make up your own profile.0
How do I test that the FTDI is working correctly ? I cannot get the amp to switch, not sure if it is the FTDI or the RJ45 board on the amp ? ARI 500 is new .
Please help w7nik..0 -
the ari has two lights .. both should be on solid .. you can also go to usb cables in smartsdr and run the log and see what is being output ..
lights are solid, the cables from the amp , should go to the amp ports on the ARI 500? conflicting information:( to the remote using the c232HM EDHSl-o
my settting are BCD tX ant, it worked the first day couple weeks age ,0 -
the cable from the flex plugs into the front ..
the amp cables plug into the back .. i have a als-1300 ..
i dont know what the c232HM EDHSl-o is ..
yes that is what i have, the BCD data is not telling the 1300 the right data .I have the FTDI cable , i would like to find out if the RJ45 board on the amp in not working or the FTDI cable . challenging0
did you buy the ready made cable ?? i made my own .. are you sure a and b cables are not reversed ?? other than that i would have no idea .. sorry .. good luck ..
I will test your FTDI maping colors, maybe something came loose0
Your mouser link is my FTDI cable0
- 246 Community Topics
- 489 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 223 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
